Export results ARSA via API
74 REPLIES 74
Message 1 of 75
mateaus
6197 Views, 74 Replies
I would like to export the results of efforts with VBA in excel files like in the video attached.
Can you help me ?
Export result
74 REPLIES 74
Message 2 of 75
Rafal.Gaweda
in reply to: mateaus
Upload the mentioned movie
Rafal Gaweda
Message 3 of 75
mateaus
in reply to: Rafal.Gaweda
It's on the link
Message 4 of 75
Rafal.Gaweda
Thanks.
Not possible to save csv from table by API. So you have to import these results to Excel then save xls file(s).
Rafal Gaweda
Message 5 of 75
mateaus
Ok, but is there a way to export results by API ?
Message 6 of 75
Rafal.Gaweda
Yes, of course.
I will write you sample code.
Rafal Gaweda
Message 7 of 75
mateaus
Could you send me an example to have list of efforts (Fx Fz My) with API VBA ?
Message 8 of 75
Rafal.Gaweda
xls file with example of table with internal forces attached.
Rafal Gaweda
Message 9 of 75
mateaus
Ok thank you,
I try it and it works but we have to select the bars before in the model. I will search by myself how to make it automaticaly and if I don't succeed I'll ask you one more time.
Just an Question. It's slow, do I need a lot of RAM to turn it faster ?
My System :
Windows XP Professionnel 2002 SP3
Intel(R) Xeon(R) CPU
W3505 @ 2.53GHz
2.53 GHz, 2.99 Go de RAM
Carte Graphique :
NVIDIA Quadro FX 580
Message 10 of 75
Rafal.Gaweda
What do you mean by that ?
No, it does not depend on RAM.
I will check the code to accelerate it - if possible.
Rafal Gaweda
Message 11 of 75
mateaus
To select automatically all the bars.
Message 12 of 75
Rafal.Gaweda
If you do not select any bar it will ask you whether to select ALL of them or stop macro.
or replace this section :
Set RSelection = RobApp.Project.Structure.Selections.Get(I_OT_BAR)
Dim BarCol As RobotBarCollection
Set BarCol = RobApp.Project.Structure.Bars.GetMany(RSelection)
If (BarCol.Count = 0) Then
If (MsgBox("No bars selected in Robot. Do you want to import results for all bars?", vbYesNo, "Warning") = vbOK) Then
RSelection.FromText "all"
RSelection.AddText "tous"
Else
Set BarCol = Nothing
Exit Sub
End If
End If
by
Set BarCol = RobApp.Project.Structure.Bars.GetAll
I am attaching updated macro.
- Faster
- You may specify number of points along bar in it (2 as a default for begining and end only)
Rafal Gaweda
Message 13 of 75
mateaus
Ok but I don't know why but if I select a bar it give me the result of the bar selected before and I have to demand a second time to have the good results for the bars selected.
Message 14 of 75
Rafal.Gaweda
Small correction in attached file.
It may happen that somehow the selection in "not confirmed" in Robot. Try to activate Bar selection filed (combo) on top of Robot on Selection toolbar (click inside it) then "confirm selection" by pressing Enter or Tab.
Rafal Gaweda
Message 15 of 75
mateaus
Ok but my goal at the end is not to have to manipulate the program Robot and only use the macro VBA in excel. Is there another solution ?
Message 16 of 75
Rafal.Gaweda
Do you mean, for example, writing selection fo bar(s) , case(s) in Excell and not to use selection from Robot? There is no problem with it. Please write down what is the workflow in your mind.
Rafal Gaweda
Message 17 of 75
mateaus
I have already modify the macro to demand bar(s) , case(s) in Excell. But I have to run the macro twice to have the good selection. I would like to do it in one time without using Robot.
Message 18 of 75
Rafal.Gaweda
PLease attach your macro.
Rafal Gaweda
Message 19 of 75
Rafal.Gaweda
My macro where the selections are read from xls file attached.
Rafal Gaweda
Message 20 of 75
mateaus
Hi, I've modified the macro to have results with an other order :
1 - Number bar
2 - Number node
2 - Cases
For example
1 / 1 / 101  Fx Fz My
1 / 1 / 102  Fx Fz My
1 / 2 / 101  Fx Fz My
1 / 2 / 102  Fx Fz My
But it's not exporting the good efforts
Would you mind correct it ?
Sub extraction_resultats_cas()
Range("A13", "F25000").Clear
Range("B5").Clear
Set RobApp = New RobotApplication
If Not RobApp.Visible Then
    Set RobApp = Nothing
    MsgBox "Open Robot and load Model", vbOKOnly, "ERROR"
    Exit Sub
Else
    If (RobApp.Project.Type <> I_PT_FRAME_3D) And (RobApp.Project.Type <> I_PT_SHELL) Then
        MsgBox "Structure Type should be FRAME 3D or SHELL", vbOKOnly, "ERROR"
        Exit Sub
    End If
    Cells(5, 1) = "Project"
    Cells(5, 2) = RobApp.Project.Name
'selection des barres
'If CheckBox1 = True Then
'Dim BarCol As RobotBarCollection
'Set BarCol = RobApp.Project.Structure.Bars.GetAll
'Else
    Dim RSelection As RobotSelection
    Dim num_bar As String
'   If (BarCol.Count = 0) Then   c'est un test de selection du modele
'       If (MsgBox("No bars selected in Robot. Do you want to import results for all bars?", vbYesNo, "Warning") = vbYes) Then
num_bar = Cells(8, 2)
    If num_bar = "" Then
        If (MsgBox("Pas de numéro de barres indiqué ! Voulez-vous selectionner toutes les barres?", vbYesNo, "Warning") = vbYes) Then
        Else
            Exit Sub
        End If
    ' ajout condition pour rentrer soi-même les numéros de barres
    Else
    RSelection.FromText num_bar
    End If
'End If
    Set RSelection = RobApp.Project.Structure.Selections.Get(I_OT_CASE)
    Dim CaseCol As RobotCaseCollection
    Set CaseCol = RobApp.Project.Structure.Cases.GetMany(RSelection)
    Dim num_cas As String
 num_cas = Cells(9, 2)
'    If (CaseCol.Count = 0) Then
    If num_cas = "" Then
        If (MsgBox("Pas de cas ou combinaisons indiqué ! Voulez-vous importer les résultats de tous les cas ?", vbYesNo, "Warning") = vbYes) Then
        Else
            Set CaseCol = Nothing
            Exit Sub
        End If
    Else
    RSelection.FromText num_cas
    End If
    Cells(9, 2) = RSelection.ToText
    NumberOfPoints = Int(Cells(10, 2).Value)
    If (NumberOfPoints < 2) Then
        MsgBox "Number of points along the bar must be greater or equal to 2", vbOKOnly, "Error"
        Exit Sub
    End If
'Sleep 10000
    Row = 12
'    Cells(Row, 1) = "Barre"
'    Cells(Row, 2) = "Noeud"
'    Cells(Row, 3) = "Cas (/ Composante)"
'     Cells(Row, 4) = "FX [kN]"
'     Cells(Row, 5) = "FZ [kN]"
'     Cells(Row, 6) = "MY [kN.m]"
     Cells(19, 9) = "Progression"
 For i = 1 To BarCol.Count
     Cells(20, 9) = Str(i) + " / " + Str(BarCol.Count)
     Dim RBar As RobotBar
     Set RBar = BarCol.Get(i)
     BarNumber = RBar.Number
     BarStr = Str(BarNumber)
     OriNodeStr = Str(RBar.StartNode)
     EndNodeStr = Str(RBar.EndNode)
     Dim BFD As RobotBarForceData
     Dim Icomp As Integer
     Dim BarForceServer As RobotBarForceServer
     Set BarForceServer = RobApp.Project.Structure.Results.Bars.Forces
     Dim Point As Double
     Dim Step As Double
     Point = 0#
     Step = 1# / (NumberOfPoints - 1)
For ii = 1 To NumberOfPoints
    For j = 1 To CaseCol.Count
        AT = CaseCol.Get(j).AnalizeType
        If AT <> I_CAT_COMB_CODE _
            And AT <> I_CAT_COMB _
            And AT <> I_CAT_COMB_NONLINEAR _
            And AT <> I_CAT_STATIC_LINEAR _
            And AT <> I_CAT_STATIC_NONLINEAR Then
                MsgBox "This macro works only for simple load cases, combinations and automatic combinations", vbOKOnly, "Error"
                Exit Sub
        End If
     UNC = CaseCol.Get(j).Number
     CaseStr = Str(UNC)
     If CaseCol.Get(j).Type = I_CT_CODE_COMBINATION Then  ' pour les combinaisons
          Dim CCount As Integer
          CCount = CaseCol.Get(j).Components.Count
          Dim StrCC As String
          StrCC = Str(CCount)
          If InStr(CaseCol.Get(j).Name, "+") <> 4 And InStr(CaseCol.Get(j).Name, "-") <> 4 And InStr(CaseCol.Get(j).Name, "+") <> 8 And InStr(CaseCol.Get(j).Name, "-") <> 8 Then
            For Icomp = 1 To CCount
                CompStr = " / " + Str(Icomp)
                    Row = Row + 1
                    If ii = 1 Then
                        Cells(Row, 1) = BarStr
                        Cells(Row, 2) = OriNodeStr
                        Cells(Row, 3) = CaseStr + CompStr
                    ElseIf ii = NumberOfPoints Then
                        Cells(Row, 2) = EndNodeStr
                    Else
                       Cells(Row, 1) = BarStr + Str(ii) + " /" + Str(NumberOfPoints) + " / " + CaseStr + CompStr
                     End If
                    Set BFD = BarForceServer.ValueEx(BarNumber, UNC, Icomp, Point)
         Cells(Row, 4) = BFD.FX * 0.001
         Cells(Row, 5) = BFD.FZ * 0.001
         Cells(Row, 6) = BFD.MY * 0.001
                    Set BFD = Nothing
          Next Icomp
          End If
     Else                                        ' pour les cas simples
         Row = Row + 1
         If ii = 1 Then
         Else
            Cells(Row, 2) = Str(ii) + " /" + Str(NumberOfPoints)
         End If
         Set BFD = BarForceServer.Value(BarNumber, UNC, Point)
         Set BFD = Nothing
     End If
     Point = Point + Step
      Next j
 Next ii
Next i
End If
Cells(19, 9) = ""
Cells(20, 9) = ""
End Sub
