Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Export from Robot to Revit structure
5 REPLIES 5
10093 Views, 5 Replies
Hi all.
i have Robot 2011 and Revit 2011 ,installed on my computer... and i have faced problem with my Robot for exporting my project to Revit.... i mean i have problem with Integration.... if so.... what i have to do to fix my problem?
regards....
5 REPLIES 5
jad.dellel
To import rtd file to Revit Structure2011, you should install the revit extensions 2011 from subscription.autodesk.com
For more information please check this document : Integrating Revit Structure and Robot Structural Analysis.
Jad DELLEL
Sustainability Success Manager - Autodesk, Inc.
in reply to: jad.dellel
i really appreciate u for ur answer... but the point is that i have downloaded the extensions from Autodesk site.. and installed them.....
but still have problem with exporting from Robot....
the Robot errors me that ( i need extensions of Revit 2011)... although i have installed them on my computer!! ....
jad.dellel
In fact, you should'nt use the Robot 's menu Add-ins -> Integration with Autodesk Revit Structure,
So to Export the rtd file to Revit Structure, you should launch the Revit Extensions 2011 and choose Update model from Autodesk Robot Structural Analysis:
Jad DELLEL
thank you veryyyyyyyy much...... this is exactly what i wanted.....
good solution... thanks man!  🙂
salam pedram.
age bekham extension baraye robot ya revit download konam az site subscription bayad chikar konam?
