Hi all.
i have Robot 2011 and Revit 2011 ,installed on my computer... and i have faced problem with my Robot for exporting my project to Revit.... i mean i have problem with Integration.... if so.... what i have to do to fix my problem?
regards....
Solved by jad.dellel. Go to Solution.
To import rtd file to Revit Structure2011, you should install the revit extensions 2011 from subscription.autodesk.com
For more information please check this document : Integrating Revit Structure and Robot Structural Analysis.
i really appreciate u for ur answer... but the point is that i have downloaded the extensions from Autodesk site.. and installed them.....
but still have problem with exporting from Robot....
the Robot errors me that ( i need extensions of Revit 2011)... although i have installed them on my computer!! ....
In fact, you should'nt use the Robot 's menu Add-ins -> Integration with Autodesk Revit Structure,
So to Export the rtd file to Revit Structure, you should launch the Revit Extensions 2011 and choose Update model from Autodesk Robot Structural Analysis:
thank you veryyyyyyyy much...... this is exactly what i wanted.....
good solution... thanks man! 🙂
salam pedram.
age bekham extension baraye robot ya revit download konam az site subscription bayad chikar konam?
