Discussion Groups
Robot Structural Analysis
Distinguished Contributor
Export Steel Slap robot to Revit structure.
297 Views, 5 Replies
12-27-2012 04:30 AM
Hi all.
I is prolem.
I design slap RC, But why I not export Steel  of robot to revit strucutre ??
Please use plain text.
Product Support
Artur.Kosakowski
Re: Export Steel Slap robot to Revit structure.
12-27-2012 04:38 AM in reply to: A.wikipedia
12-27-2012 04:44 AM in reply to: Artur.Kosakowski
Thank Artur.
But I don't kwon Artut write : " On the other hand you can export it to ASD Reinforcement and generated dwg drawings there which you can link with the Revit model."
I do not Export  ASD Reinforcement to Revit Modol???
Product Support
Artur.Kosakowski
12-27-2012 04:51 AM in reply to: A.wikipedia
It is not possible to directly export  reinforcement of slab generated in Robot to Revit but you may find the following solution helpful:
1. Generate slab reinforcement drawing in Robot
2. Open this drawing in ASD reinforcement and save it as dwg
3. Link this dwg file with the project in Revit
Artur Kosakowski
12-27-2012 05:19 AM in reply to: Artur.Kosakowski
Thank you.
But I do not use steel of revit structure.?????
Please see video.
http://www.screencast.com/t/ZBMO8OtzQZh
Thank again.
Product Support
Artur.Kosakowski
12-27-2012 05:28 AM in reply to: A.wikipedia
As you linked the 2D dwg drawing you will not be able to generate a cross section using Revit tool that is intended for a 3D model. The cross section view should be created in ASD and saved in the same or as a separate dwg file (that you link to Revit).
Artur Kosakowski
