Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Execution problem no 902
3 REPLIES 3
bjornhgr
4203 Views, 3 Replies
During non-linear analysis on a structure with planar rigid supports with released uplift, I get an error displaying "execution problem no 902". What might cause this?
BMan
3 REPLIES 3
Rafal.Gaweda
in reply to: bjornhgr
If it is not the case please send us model
Rafal Gaweda
Artur.Kosakowski
Please mind the limitations of the modal analysis for non-linear models
See e.g. message 4 from http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Uplift/m-p/3320823/
also http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Barre-de-treillis-traction-compression-vs-s%...
Artur Kosakowski
bjornhgr
Thanks! Think I got my answer there. No good idea to combine non linear supports and seismic modal analysis. And since I'm not about to do a time history analysis, I guess that leaves me with the mentioned method of transferring results from the seismic analysis to a separate model with non linear supports.
Thanks a lot!
BMan
