Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Exchanging information between 2 projects
11 REPLIES 11
Message 1 of 12
stroxy
403 Views, 11 Replies
I created polylines in a model along the slab edges and added wind loading to them.  I am now working with a different model of the same project.  Is there a way to bring the polylines into my new model without having to redraw them.  Saving and Updating Substructure  did not seem to work.  Also copy and pasting did not work either.
11 REPLIES 11
Message 2 of 12
Rafal.Gaweda
in reply to: stroxy
I will check it.
Rafal Gaweda
Message 3 of 12
stroxy
in reply to: Rafal.Gaweda
Thanks!!
Message 4 of 12
stroxy
in reply to: stroxy
Any solutions on this?
Message 5 of 12
Rafal.Gaweda
in reply to: stroxy
- select lines ,polylines, whatever
- Geometry \ Structure \ Save Substructure
- in new model Geometry \ Structure \ Insert from file , select *.rtd extension mask, select saved file
Rafal Gaweda
Message 6 of 12
stroxy
Ok it sort of works.  The polylines cappeared alright but were not inserted at the correct location.  I guess it has something to do with the attached dialog box.
Message 7 of 12
Rafal.Gaweda
in reply to: stroxy
Yes, insert them in "easy to use" place then move to correct location or...
Usually the insertion point is the node with the lowest number. So add node number 1 somewhere to polyline file and then Robot should treat it as a reference for insertion.
Rafal Gaweda
Message 8 of 12
stroxy
Thanks, also i noticed it leads as in a 3d view, and I seem to have lost my "plan" view tab
Message 9 of 12
stroxy
in reply to: stroxy
Also do i add as object? (lower part of dialog box)
Message 10 of 12
Rafal.Gaweda
in reply to: stroxy
I do not recommend
Rafal Gaweda
Message 11 of 12
stroxy
Merci!!
How do I restore the "plan" view tab?  After bringing in the file I only have the 3d view, which I can orientate to xy plane, but I am missing the dedicated "plan" view where I can show column shapes in plan view.
Message 12 of 12
Rafal.Gaweda
in reply to: stroxy
Geometry \ Structure Type -> select Building Design
Rafal Gaweda
