Dear Supports,
i am using Autodesk robot 2014 professional with Latest service packs.
When I verify the design report I note that the normal forces shown in table 7.21 for the chord web yielding stability is not done (See the table attached and the design report).
thank you in advance.
Wassim
Could you attach the rtd file with the connection please? Thank you.
Dear Artur,
Kindly find attached the portion of the lattice Tower with the related steel connection.
Note that I found the verification of the beam web yielding under normal forces is not done in Robot for this Type of connection.
(only web buckling due to bending moment is verifed).
Your help is very appreciated.
Thank you
Wassim
ATTCHMENT:
http://www.4shared.com/zip/IhMyEN0Yba/Portion_of_the_Lattice_Tower.html
Introduced in SP1 for Robot 2015.
Thank you Artur,
I will try it when I can download the Robot 2015 with the SP1.
