Is there anyway to estimate the required rc slab depth in Robot? or how can I estimate the intial slab depth in Robot?
James
Solved by Artur.Kosakowski. Go to Solution.
No there is nothing like that. You have to decide about panel thickness ; if it is not sufficient you have to change it or material grade(s)....
You may find these basic rules helpful.
http://theconstructor.org/structural-engg/design-of-slab-basics/5017/
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
