Error unable to find ASMm218res.​dll file
14 REPLIES 14
Message 1 of 15
LieberSteve4929
3151 Views, 14 Replies
Am getting error unable to find ./en-us/asmm218res.dll file.  This is happening when I go to import a autodesk file, the program then shuts down.  Where do I go to trouble shoot this issue?
Thanks Steve
Tags (1)
14 REPLIES 14
Message 2 of 15
For now workaround:
Copy
c:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\x64\ROReinf\ASMm218res.dll
to
c:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\System\Exe\en-US\ASMm218res.dll
Rafal Gaweda
Message 3 of 15
jorge.lopera
in reply to: Rafal.Gaweda
It happens the same to me,
the procedure is correct, allows to import.
Thanks!!!
Technical Specialist
Nexsys de Colombia
Message 4 of 15
Hi guys,
I get this error when I try to import and cad file (dwg or dxf).
Please advise........
Tony
Message 5 of 15
Message 6 of 15
Serdar-C
Hello from Turkey ,
I have a similar problem ,but a little bit different.
I am using spec editor. And I'm gonna add custom part at catalog builder . Consists of a problem at this time.
"Unable to find " error.
Autocad don't find  tr-TR\asmm218res.dll  , so am I.
I can't find tr-TR folder in Program Files.
Also, there isn't Robot structural ...... folder.!!!
Where should I'll find tr-TR folder ?
Tags (1)
Message 7 of 15
Rafal.Gaweda
in reply to: Serdar-C
Strange, there is no tr-TR folder becasue there is no turkish version but, create this folder:
(W7)
"c:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\System\Exe\tr-TR"
then copy contents of
"c:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\System\Exe\en-US"  folder
to this tr-TR folder
Rafal Gaweda
Message 8 of 15
Serdar-C
Hello and many thanks !
But, there is not "Autodesk Robot Structural Analysis Professional 2013 " in my Autodesk folder.
I think this is different application for Autocad.
 Where should I create file ? Or  where should I copy this .dll ? Or which "system" folder?
Message 9 of 15
Rafal.Gaweda
I am afraid you have posted your message to wrong forum.
It is Robot forum, not ACAD.
Rafal Gaweda
Message 10 of 15
I have the same problem , but I could'n find the "2013" file I have instead two files "2012" and "2011" , in this two files I coudnt find  "x68" file I have instead " x86". Help plaiiiiiiiiiiiise
Message 11 of 15
Are you talking about Robot 2011 or 2012?
Such file does not exist in these versions at all.
Rafal Gaweda
Message 12 of 15
I have 2013 version, I download it from autodesk website.
Message 13 of 15
Dll file attached
Rafal Gaweda
Message 14 of 15
You sent me a shortcut not the file . Thanks any way Smiley Happy
Message 15 of 15
Sorry, correct dll attached.
Rafal Gaweda
