Hello.
I have modeled and designed a multi storey concrete building. A had model structure and soil in the same place.
But there is a problem . When I want to transfer an element to provided module, first I can't select simple model . It's button is gray. Next when I run calculation button in provided module nothing happen. I have attached a picture and a file. Could you please help me?
Thank you.
Solved by Artur.Kosakowski. Go to Solution.
I have restored the missing relations among simple load cases that the RC Design module needs.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Thank you . But how do you do this correction?
Next time if I encounter with this problem what should I do?
