Discussion Groups
Robot Structural Analysis
Valued Contributor
MohammadZaman
Error on provided reinforcement
267 Views, 3 Replies
10-08-2012 12:34 AM
Hello.
I  have modeled and designed a multi storey concrete building.  A had model structure and soil in the same place.
But there is a problem . When I want to transfer an element to provided module, first I can't select simple model . It's button is gray. Next when I run calculation button in provided module nothing happen. I have attached a picture and a file. Could you please help me?
Thank you.
Please use plain text.
Product Support
Artur.Kosakowski
Re: Error on provided reinforcement
10-08-2012 02:52 AM in reply to: MohammadZaman
I have restored the missing relations among simple load cases that the RC Design module needs.
Artur Kosakowski
Valued Contributor
MohammadZaman
10-08-2012 03:17 AM in reply to: Artur.Kosakowski
Thank you . But how do you do this correction?
Next time if I encounter with this problem what should I do?
Product Support
Artur.Kosakowski
10-08-2012 04:01 AM in reply to: MohammadZaman
Artur Kosakowski
