Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Error in reading sections data-check the sections database
5 REPLIES 5
mail2mr1
1466 Views, 5 Replies
I just started trying out Robot. I can't seem to resolve an "Error in reading sections data-check the sections database". Any suggestions.
Bill
5 REPLIES 5
Artur.Kosakowski
in reply to: mail2mr1
Bill,
When exactly this message is displayed? The moment you start Robot? Could you make its screen capture and attach it please?
Artur Kosakowski
mail2mr1
in reply to: Artur.Kosakowski
Artur
Re: Error in reading sections data-check the sections database
I get the following error message after:
1. I open Robot
2. Load a project
3. Go to Geometry menu
4. Go to Properties
5. Go to Sections
6. Attempt to open a section selection from the properties database.
Bill
ERROR MESSAGE BELOW:
" See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Runtime.InteropServices.COMException (0x80040154): Retrieving the COM class factory for component with CLSID {5C257DA9-418F-11DF-BDA4-002264AF06AC} failed due to the following error: 80040154.
   at DRobotSectLblMngr.frmSectionLabelManager.ComboBox1_TextChanged(Object eventSender, EventArgs eventArgs)
   at System.Windows.Forms.Control.OnTextChanged(EventArgs e)
   at System.Windows.Forms.ComboBox.set_SelectedIndex(Int32 value)
   at DRobotSectLblMngr.frmSectionLabelManager.Init()
   at DRobotSectLblMngr.Main.MainOnTimer()
   at DRobotSectLblMngr.frmTimer.Timer1_Tick(Object eventSender, EventArgs eventArgs)
   at System.Windows.Forms.Timer.OnTick(EventArgs e)
   at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.5446 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
RobwinInterop
    Assembly Version: 0.0.0.0
    Win32 Version: 25,0,0,3774
    CodeBase: file:///C:/Program%20Files/Autodesk/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/RobwinInterop.DLL
msvcm90
    Assembly Version: 9.0.30729.4940
    Win32 Version: 9.00.30729.4940
    CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4940_none_08e4299fa83d7e3c/msvcm90.dll
System
    Win32 Version: 2.0.50727.5447 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
AdWindows
    Assembly Version: 3.2.25.0
    Win32 Version: 3.2.25.0
    CodeBase: file:///C:/Program%20Files/Autodesk/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/AdWindows.DLL
PresentationCore
    Assembly Version: 3.0.0.0
    Win32 Version: 3.0.6920.5011 built by: Win7SP1
    CodeBase: file:///C:/Windows/assembly/GAC_64/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
WindowsBase
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationFramework
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll
System.Xml
    Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
AdApplicationFrame
    CodeBase: file:///C:/Program%20Files/Autodesk/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/AdApplicationFrame.DLL
PresentationFramework.Aero
    Win32 Version: 3.0.6920.4902 built by: NetFXw7
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework.Aero/3.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
RobwinRibbon
    Assembly Version: 1.0.0.0
    Win32 Version: 25.0.0.3774
    CodeBase: file:///C:/Program%20Files/Autodesk/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/RobwinRibbon.DLL
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Autodesk.Common.DOptionSetOrganizer
    Assembly Version: 23.0.0.0
    Win32 Version: 25.0.0.3756
    CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Structural/COM/2012/DOptionSetOrganizer/Autodesk.Common.DOptionSetOrganizer.dll
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Autodesk.Common.DOptionSetOrganizer.Resources
    Win32 Version: 23.0.0.0
    CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Structural/COM/2012/DOptionSetOrganizer/en-US/Autodesk.Common.DOptionSetOrganizer.resources.DLL
Autodesk.Common.DTabControlSelector
    CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Structural/COM/2012/DTabControlSelector/Autodesk.Common.DTabControlSelector.dll
Autodesk.Common.DTabControlSelector.Resources
    CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Structural/COM/2012/DTabControlSelector/en-US/Autodesk.Common.DTabControlSelector.resources.DLL
Accessibility
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Autodesk.REX.Loader
    Win32 Version: 2012.0.0.1769
    CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Loader/Autodesk.REX.Loader.dll
Autodesk.REX.Framework
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Autodesk.REX.Framework/1.0.0.0__51e16e3b26b42eda/Autodesk.REX.Framework.dll
Autodesk.Common.AResourcesControl
    Win32 Version: 2012.0.0.0
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Autodesk.Common.AResourcesControl/1.0.0.0__ff3304d4f320ee59/Autodesk.Common.AResourcesControl.dll
AREXRobotMngr
    Assembly Version: 2012.0.0.1161
    Win32 Version: 2012.0.0.1161
    CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Products/Robot/AREXRobotMngr.dll
Interop.RobotOM
    CodeBase: file:///C:/Program%20Files/Autodesk/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/Interop.RobotOM.DLL
REX.Manager
    Assembly Version: 2012.0.0.1769
    CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.Manager.dll
REX.Engine
    Assembly Version: 2012.0.0.1422
    CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.Engine.dll
REX.Preferences
    CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.Preferences.DLL
REX.System
    CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.System.DLL
REX.UI.WPF
    CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.UI.WPF.DLL
REX.UI
    CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.UI.DLL
REX.UI.Forms
    Assembly Version: 2012.0.0.1642
    CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.UI.Forms.DLL
REX.UI.Resources
    CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/en-US/REX.UI.resources.DLL
REX.Foundation
    CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Foundation/REX.Foundation.dll
REX.System.Resources
    CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/en-US/REX.System.resources.dll
REX.Manager.Resources
    CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/en-US/REX.Manager.resources.dll
DRobotSectLblMngr
    CodeBase: file:///C:/Program%20Files/Autodesk/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/DRobotSectLblMngr.DLL
Microsoft.VisualBasic
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.5420 (Win7SP1.050727-5400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
DRobotSectLblMngr.Resources
    CodeBase: file:///C:/Program%20Files/Autodesk/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/en-US/DRobotSectLblMngr.resources.DLL
Interop.syspathsLib
    Assembly Version: 5.0.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/Interop.syspathsLib.DLL
Interop.IDbRootLib
    CodeBase: file:///C:/Program%20Files/Autodesk/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/Interop.IDbRootLib.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box. "
Bill
Artur.Kosakowski
Bill,
Thank you for this information. Could you tell me what section databases are declared in your Job Preferences? Could you remove all of them but ruser (user section database) and then add them one by one to the list to see if any particular database from the original list is the cause of this situation please?
Artur Kosakowski
Bill,
I have assumed you know that you can add a new section using the New Section definition icon rather than Section selection one from the database but then I realized that you actually may not know this so I decided to make this additional post. Of course the question about the list of databases you have got declared is still valid.
Artur Kosakowski
Artur.Kosakowski
Bill,
Please download and install SP1 for Robot 2012 (mind to select the correct version of the pack depending on the version of Robot you have installed) from http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=13140816
If you have 64-bit system you will need to install HF2 as well which will be available on this site later today or tomorrow.
Artur Kosakowski
