Error: Faces (The objects without assigned thickness) not used in solid area generation. FE mesh has not been generated.
What does this error mean? It is on a cladding with distributed load. Only one of the claddings in my model shows this behaviour.
Solved by TorgrimO. Go to Solution.
Do you have any load defined on this cladding? If no, try to add one.
Yes I do. According to the load distribution plots, it looks fine though.
