Hello, I need some help please!
At the end of the seismic analysis, Robot doesn't save the resultas intead of that I have an error message N 925 execution problems? what the solution ??? Thanks
I saved the project in an external hard disk , it has 407 Go free memory, the C disk has only 4.34 Go free memory, that's enough I think for now it's still calculating.
on C drive (or where %temp% folder is located) should be ~7-8 GB free and additional 7-8 GB where you want to save file.
With saving quadratic combinations (as you have defined in model) you need 12 GB free on C (or where % temp% is located) AND 12 GB free where the file should be saved.
If I displace the "temp" folder into the D drive would that cause a problem?
