Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Erro nonlinear problem
17 REPLIES 17
Message 1 of 18
athurD
656 Views, 17 Replies
Hi.
When calculation i is problem.
17 REPLIES 17
Message 2 of 18
Rafal.Gaweda
in reply to: athurD
Try this : http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Non-linear-Static-Analysis-Parameters/m-p/36...
if it does not help please send us model.
Rafal Gaweda
Message 3 of 18
athurD
in reply to: Rafal.Gaweda
Thank you.
File modol of me.
http://www.mediafire.com/?cv1hf8c1sjg5hck
pass PM (RG_Adsk)
Message 4 of 18
Rafal.Gaweda
in reply to: athurD
The model you send me is linear:
Rafal Gaweda
Message 5 of 18
athurD
Sorry.
you please add the same picture.
Thanks.
Message 6 of 18
Rafal.Gaweda
in reply to: athurD
I do not see any problem with Newton Raphson algorithm.
calculation times:
all cases, Newton Raphson, Sparse Solver - 2227seconds
simple cases set as auxiliary, Newton Raphson, multithreaded solver - 1700seconds - such model here :
https://www.filemail.com/dl.aspx?id=JZOUWLOFNSEKABA
Rafal Gaweda
Message 7 of 18
athurD
thank you very much.
You let me ask one question.
By my modol, then I should choose it is U + or U-?????
To get the correct results.
Message 8 of 18
Rafal.Gaweda
in reply to: athurD
It depends on local Z of panel
in your case U+
Examples:
Rafal Gaweda
Message 9 of 18
athurD
Hi.
I is prolem again, when change foundation raft to foundation footing???????
File modol foundation Footing. Please help.
http://www.mediafire.com/?po19hlc631a41ni
Message 10 of 18
Rafal.Gaweda
in reply to: athurD
No support s in UX UY directions.
I suggest you to use Automatic solver - it will report instabilities in model.
Rafal Gaweda
Message 11 of 18
athurD
Thank you reply.
I selection Automatic solver. File modol run normal.
I show deformation combo1 normal, So why Combo2,3,4,5,6,7 deformation verry max????????/. Please see picture.
Message 12 of 18
Rafal.Gaweda
RG_Adsk wrote:
"No support s in UX UY directions."
It means ADD such supports.
Example below
Rafal Gaweda
Message 13 of 18
athurD
Thank you verry much.
I do not know to add ux, Uy.
Add it using the tool???
Message 14 of 18
athurD
in reply to: athurD
Please guide me App support in UX UY directions same picture RG_Adsk  ???.
I desperately needed for my work.
Thanks.
Message 15 of 18
tony.ridley
in reply to: athurD
WHy are you modelling structures if you do not understand this?
Message 16 of 18
athurD
in reply to: tony.ridley
Sorry tony.
If you can tell me, I do not know what I asked.
Message 17 of 18
Rafal.Gaweda
in reply to: athurD
example : http://screencast.com/t/ReS4UpwDF
Rafal Gaweda
Message 18 of 18
athurD
thank you.
