Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Equivalent static analysis.
5 REPLIES 5
707 Views, 5 Replies
Hi again,
When using equivalent static analysis for EQ to AS1170.4, why can't you use the results in a combination with non linearity (ie a non-linear combination, or one that includes non-linear member properties i.e. tension only)?
I'm thinking that the equivalent static analysis does not work correctly for models with non-linear members.  Please correct me if I'm wrong.
Cheers,
Tony
5 REPLIES 5
Pawel.Pulak
Hi Tony,
you are right - components from equivalent static analysis are ignored in non-linear combinations :(.
Escalated to dev team. I will notify you after change.
Pawel Pulak
Technical Account Specialist
in reply to: Pawel.Pulak
It's important because you obviously need to add the lateral load to the gravity cases.  It's a bit useless otherwise.
Tony
Artur.Kosakowski
Introduced in SP4 for Robot 2013. Please check for the availability of this update at the beginning of the next week.
Artur Kosakowski
in reply to: Artur.Kosakowski
Robot 2103?
I will be doing spectral analysis by telepathy by then 😛
Artur.Kosakowski
Corrected  Smiley Happy
Artur Kosakowski
