Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Envelop problem
4 REPLIES 4
sedefass
689 Views, 4 Replies
Envelop problem
When I select some of my combinations RSAP should make an envelop diagram, but it does it just for the simple cases, not for the combinations.
Please see the attached pictures.
Thank you in advance
4 REPLIES 4
Rafal.Gaweda
in reply to: sedefass
Please send us the file.
Rafal Gaweda
sedefass
in reply to: Rafal.Gaweda
Here is the file.
Rafal.Gaweda
It seems the reason can be combination type 2SM for comb 23 24.
IN the attached corrected file the envelopes are generated for all combinatinos except 23 and 24 ;
23 and 24 are also not taken into account for any envelope generation.
If you change them onto CQC or SRSS everything will be fine (another file attached).
Rafal Gaweda
sedefass
Thank you very very much! Now it works just fine!
