I have trouble modelling a Joint in a tunnel. The joint is made as an elastic realease with a k=25000 kNm/rad. However when i back calculate from the results Robot gives me in form of rotation and moment they don't fit together. For 2 of my joint the rotational stiffness increase and for one it decreases.
Do i need to use a different approach or can i force the program to run more calculation or something.
Best Regards Peter
Solved by Artur.Kosakowski. Go to Solution.
Mind to compare values taken from the calculation nodes created by DSC algorithm for releases.
Hey Arthur,
I see my problem now, only thing left for you to solve is: How do I get node 101 102 and 103 to show up in my tables. I can see them in my view but can't get them to display in my tables.
Br PEOV
RMB on the displacements table > Table Columns > General tab
Check the attached picture in the message 5 from http://forums.autodesk.com/t5/Robot-Structural-Analysis/Node-that-does-not-exist/m-p/4655919
