Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Elastic release in rotation joint (concrete)
5 REPLIES 5
894 Views, 5 Replies
I have trouble modelling a Joint in a tunnel. The joint is made as an elastic realease with a k=25000 kNm/rad. However when i back calculate from the results Robot gives me in form of rotation and moment they don't fit together. For 2 of my joint the rotational stiffness increase and for one it decreases.
Do i need to use a different approach or can i force the program to run more calculation or something.
Best Regards Peter
5 REPLIES 5
Rafal.Gaweda
File please.
Rafal Gaweda
in reply to: Rafal.Gaweda
Here you go 😄
Artur.Kosakowski
Mind to compare values taken from the calculation nodes created by DSC algorithm for releases.
Artur Kosakowski
in reply to: Artur.Kosakowski
Hey Arthur,
I see my problem now, only thing left for you to solve is: How do I get node 101 102 and 103 to show up in my tables. I can see them in my view but can't get them to display in my tables.
Br PEOV
Artur.Kosakowski
RMB on the displacements table > Table Columns > General tab
Check the attached picture in the message 5 from http://forums.autodesk.com/t5/Robot-Structural-Analysis/Node-that-does-not-exist/m-p/4655919
Artur Kosakowski
