Elastic release in rotation joint (concrete)
5 REPLIES 5
PEOV
890 Views, 5 Replies
I have trouble modelling a Joint in a tunnel. The joint is made as an elastic realease with a k=25000 kNm/rad. However when i back calculate from the results Robot gives me in form of rotation and moment they don't fit together. For 2 of my joint the rotational stiffness increase and for one it decreases.
Do i need to use a different approach or can i force the program to run more calculation or something.
Best Regards Peter
5 REPLIES 5
Rafal.Gaweda
in reply to: PEOV
File please.
Rafal Gaweda
PEOV
in reply to: Rafal.Gaweda
Here you go 😄
Artur.Kosakowski
in reply to: PEOV
Mind to compare values taken from the calculation nodes created by DSC algorithm for releases.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
PEOV
in reply to: Artur.Kosakowski
Hey Arthur,
I see my problem now, only thing left for you to solve is: How do I get node 101 102 and 103 to show up in my tables. I can see them in my view but can't get them to display in my tables.
Br PEOV
Artur.Kosakowski
in reply to: PEOV
RMB on the displacements table > Table Columns > General tab
Check the attached picture in the message 5 from http://forums.autodesk.com/t5/Robot-Structural-Analysis/Node-that-does-not-exist/m-p/4655919
Artur Kosakowski
