Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Elastic ground bar definition
9 REPLIES 9
Message 1 of 10
HoshangMustafa
2064 Views, 9 Replies
Hi
Why is the unit of Kz set to kpa? Isn't it kpa/m
If I got a bearing capacity of 10ton/m2, how much will be Kz?
9 REPLIES 9
Message 2 of 10
Force needed to move a unit length of a bar by the unit of displacement.
KZ is not the same as bearing capacity.
You can use the KZ calculator to estimate this value based on the properties of soil.
Artur Kosakowski
Message 3 of 10
Hi
How can i model Tie beam on ground?
Should I use elastic ground bar or Bar with linear support?
Message 4 of 10
A linear support is not applicable for bars. You should use a bar on elastic ground instead.
Artur Kosakowski
Message 5 of 10
Thanx
Accept as answer
Message 6 of 10
Hi
how can I combine two continuous footing into one continuous footing if the spacing between them is very small or overlapped each other?
Message 7 of 10
Could you make a sketch that illustrates this situation?
Artur Kosakowski
Message 8 of 10
Hi
The attached file shows a sketch of a situation of combined continuous footing
I hope you can help solving
Message 9 of 10
You may consider modeling them as a panel on elastic soil instead.
Artur Kosakowski
Message 10 of 10
in which program did you calculate these nonlinear coefficients?
