I would like to create an elastic foundation on a element with Robot API in VB.
Have a look to the video please.
Can you give me the code ?
Solved by Rafal.Gaweda. Go to Solution.
Dim ElasticGroundLabel As RobotLabel
Dim ElaData As RobotBarElasticGroundData
Set ElasticGroundLabel = Robapp.Project.Structure.Labels.Create(I_LT_BAR_ELASTIC_GROUND, "my_ground")
Set ElaData = ElasticGroundLabel.Data
ElaData.KZ = 10000
Robapp.Project.Structure.Labels.Store ElasticGroundLabel
I would like to create an elastic foundation on a panel (KZ , KY and Kx ) with Robot API in VBA and thank you
Hi Rafal.Gaweda
How to insert a value for Kx and Ky (Tangent foundation) ? and thank you
It is not implemented in API so it does not matter which language You C++, C#, VB, VBA, Python, Dynamo etc.
Hi Rafal Gaweda
How to define nodes in loads and thank you
