Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Elastic Foundation with API VBA
14 REPLIES 14
Message 1 of 15
1009 Views, 14 Replies
I would like to create an elastic foundation on a element with Robot API in VB.
Have a look to the video please.
Can you give me the code ?
14 REPLIES 14
Message 2 of 15
Rafal.Gaweda
Dim ElasticGroundLabel As RobotLabel
Dim ElaData As RobotBarElasticGroundData
Set ElasticGroundLabel = Robapp.Project.Structure.Labels.Create(I_LT_BAR_ELASTIC_GROUND, "my_ground")
Set ElaData = ElasticGroundLabel.Data
ElaData.KZ = 10000
Robapp.Project.Structure.Labels.Store ElasticGroundLabel
Rafal Gaweda
Message 3 of 15
in reply to: Rafal.Gaweda
Ok how can I apply to a element ? for example number 4.
Message 4 of 15
Rafal.Gaweda
Dim Bar As RobotBar
Set Bar = RobApp.Project.Structure.Bars.Get(4)
Bar.SetLabel I_LT_BAR_ELASTIC_GROUND, "my_ground"
Rafal Gaweda
Tags (1)
Message 5 of 15
I would like to create an elastic foundation on a panel (KZ , KY and Kx ) with Robot API in VBA and thank you
Message 6 of 15
Message 7 of 15
Hi
Message 8 of 15
Hi @bensalahsayf.edd
Not implemented in API.
Rafal Gaweda
Message 9 of 15
Thank you , But have you another solution ?
Message 10 of 15
Use planar support instead.
Rafal Gaweda
Message 11 of 15
I used but is not the same result 😞
Message 12 of 15
Hi
Message 13 of 15
It is not implemented in API so it does not matter which language You C++, C#, VB, VBA, Python, Dynamo etc.
Rafal Gaweda
Message 14 of 15
Okey and thank you
Message 15 of 15
Hi Rafal Gaweda
How to define nodes in loads and thank you 
Tags (1)
