Hi guys,
I need to send a Robot file to a client, and contain as much data as possible i.e. loads, load cases, bar properties etc.
Is the best way to do it a .str text file?
For example, I have opened StaadPro files directly in Robot - they come in with all the loads on members etc. Is there another package that can read a Robot file directly (same as how Robot reads Staad)?
Cheers,
Tony
Solved by Artur.Kosakowski. Go to Solution.
Tony,
I'm sorry but we haven't developed any devoted tool to save Robot file in other application format deciding to leave this part to 'them'
I don't know what kind of model you created but using the members key word I would try to save it in DSTV or CIS/2 formats. You may use str as well (it may not contain all information but as it is the text format then t is 'easy' to understand).
Thanks Artur.
I'm happy to send .str................only asking to make sure I cover all possibilities.
BTW If someone sends me an analysis file I only ever get text files or worse 3D cad.
This is when genius of API comes into play to convert the text file into a robot file.
(I think Rafal knows a guy, who has a friend that is familiar with the Robot API)
But you are right, let "them" work it out by themselves.
Tony
