Discussion Groups
Robot Structural Analysis
Active Member
nvgeirinhas
Dynamic degrees of freedom error
579 Views, 9 Replies
02-14-2013 04:18 PM
I have a structure, but when I run the calculations I have this error: "Number of dynamic degrees of freedom equals 0"
I think that is related to the application of the earthquake.
I can't solve it. Any suggestions?
Best Regards
Please use plain text.
Product Support
Artur.Kosakowski
Re: Dynamic degrees of freedom error
02-14-2013 11:46 PM in reply to: nvgeirinhas
Most likely you defined supports in all nodes or you set 'disregard' density in the parameters of  the modal analysis without making any load to mass conversion. Otherwise I need the model to check.
Artur Kosakowski
Active Member
nvgeirinhas
02-17-2013 04:34 AM in reply to: Artur.Kosakowski
Hello
My parameters on modal analysis are this. Whow can I send the file to you?
Best Regards
Nuno Geirinhas
Product Support
Artur.Kosakowski
02-18-2013 12:32 AM in reply to: nvgeirinhas
Save the file with under a new name with no results and then compress it (*.zip). Then you can attach it to the post.
If it is too large use one of the free web services for file transfer and attach the link to download the file.
Artur Kosakowski
Active Member
nvgeirinhas
02-18-2013 07:42 AM in reply to: nvgeirinhas
I send attach the file.
Product Support
Artur.Kosakowski
02-18-2013 07:51 AM in reply to: nvgeirinhas
"Most likely you defined supports in all nodes .."
Divide bars e.g. in this way:
Artur Kosakowski
Member
gabriel-razvan.cristian
06-12-2014 09:00 AM in reply to: nvgeirinhas
Hello Athur,
I have the same problem with the "Number of dynamic degrees of freedom equals 0.".
I try to divied the Edge 1 in more elements, but I still have this problem. My objectiv is to find the modal analysis of a dam.
Could you or somebody help me please to solve this issue?
Thanks in advance,
Razvan
Product Support
Artur.Kosakowski
07-02-2014 04:03 AM in reply to: gabriel-razvan.cristian
This needs to be addressed by the development team.
Artur Kosakowski
Product Support
pp2008
07-02-2014 04:48 AM in reply to: Artur.Kosakowski
Some workaround may be replacing your plane strain model by volumetric one.
Attached the file where I converted your model to solid - 10 meter slice of the dam modeled, additional face supports added to make it coherent with plane strain constraints.
A have deleted the loads - it will be necesary to re-define them as surface loads.
I have also noticed that you attempted to convert water pressure load into masses. Usually considering the pressure of liquid in vibrations is not so simple - there were some references considering it in some other post on this forum.
Best regards,
Pawel Pulak
Active Contributor
mjoflor
07-05-2014 06:12 PM in reply to: pp2008
There is no load to mass conversion, it need for modal analysis,
