Dear sir
kindly find attached file
we have robot model for block ( slabs - columns-....).but when i add drop panel in ground floor & basements i got an illogical results. negative moment at column ( see pic 1-2) for example : drop panel no: 1753-1755
regards
Solved by Artur.Kosakowski. Go to Solution.
Try to switch the reduction over supports on.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
