Hi!
Is it possible to display bar results in a plane, like with panel section?
For example, I have My moment, but it is only visible in XZ plane and/or 3D, not in XY plane.
Is there a way to "rotate" bar diagrams?
Solved by Romanich. Go to Solution.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
HI everyone,
you can use detailed result for bars: in this way if you select the the bar that you want to investigate you can see, in a different robot window, all the diagram you want, exept for deflection that appear only in table results. You can also select or create a table for a user defined poit.
You can also select more beams, only if they are complanar.
Merry Christmas everybody
In "Building" structure type it acctually works. In PLAN view I get what I wanted.
Thank you both!
