Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Display acceleration settings
7 REPLIES 7
Message 1 of 8
943 Views, 7 Replies
I've got 2 Nvidia Quadro K600 video graphic cards on my computer. I tried to increase display acceleration in robot settings in order to increase productivity. By default it's set to 1/3 of maximum. If I increase it and restart robot, it doesn't display model at all. I have latest drivers installed on my computer.
Does anyone know why this is happening and how to solve it?
Thanks!
7 REPLIES 7
Message 2 of 8
Mirko.Jurcevic
I had the same problem. Solution is: don't pull it to maximum or it won't display model correctly.
I don't know why this happens, guys from Autodesk tech support probably knows, my colegaue said to me that the same problem exists on AutoCAD, on some computers it works, on others don't.
Something to do with Autodesk certified display adapters drivers or something.
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
Message 3 of 8
in reply to: Mirko.Jurcevic
That's an obvious solution:-)
Support team, could you respond? Is there any specific version of driver that I should install to solve this issue?
Message 4 of 8
Rafal.Gaweda
No special requirements. Use card, drivers certified for Revit.
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
Rafal Gaweda
Message 5 of 8
in reply to: Rafal.Gaweda
Rafal,
I just updated the driver using your link. I chose one for revit 2014. The result is still the same. Do you have any other ideas?
Message 6 of 8
Rafal.Gaweda
But what is your problem?
Set 1/3 or 2/3 acceleration
Rafal Gaweda
Message 7 of 8
My problem is that I can't set it even to 2/3, only 1/3.
I want everything to be smooth:-)
Message 8 of 8
I still have this problem.
I got a N-Vidia Quadro 4000 totally updated and graphic acceleration doesn't work unless maintain as default.
Is anybody working with full display acceleration?
Regards
