Why the display menu is diferent according to the pictures attached. The robot versions are the same (2013) but on diferent computers.
Bets regards
Nuno Geirinhas
Solved by Rafal.Gaweda. Go to Solution.
ON the computer where you made robot.png screen shot:
Remove these two folders with all contents
C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\DOptionSetOrganizer
C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\DTabControlSelector
then unistall Robot 2013, then install it again
