Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Direction of seismic excitation
4 REPLIES 4
904 Views, 4 Replies
According to EN 1998-1:2004 4.3.3.1 (11), the seismic excitation must be applied to all relevant directions.
For some structures there might be more than 2 relevant directions, and these directions may deviate from the directions of the global X- and Y-direction in the Robot model.
In my understanding of Robot, this should be possible when using the button "direction definition" in the "EN 1998 Parameters" dialog box.
I have tried this to a simple model, but it does not seem to work properly.
Have anyone tried something similar, with good results?
Tags (2)
4 REPLIES 4
Romanich
you must use Quadratic or Newmark combinations:
Also, you can read p.15.8 from Mr. Wilson book
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
MARIOS75
Keep in mind that unlike Newmark combination rule, SRSS rule is not direction dependant.
Rotating the building + newmark rule i guess will do the job.
mark.martin.se
in reply to: MARIOS75
Hi,....
....just to clarify,.... According to EC8 all the structure's members should "resist" 100% of the prescribed seismic forces in one direction plus 30%  of the prescribed forces in the perpendicular direction!
i.e.:
1Edx"+"0,3Edy
0,3Edx"+1Edy
when Z direction is disregarded.
So, what I need to check in the "Direction definition" is......
Am I wrong?
Regards
in reply to: mark.martin.se
You seem to have set it up correctly.
