Hello.
I have selected PN Metric Rebar, But after design procedure it shows and selects Imperial rebar. I have attached a picture and a file.
Could you please help me?
Thank you.
Solved by Artur.Kosakowski. Go to Solution.
You should choose the database on which you want to work .
see attachment.
If you see my picture that attached you will see that i selected Metric database and i want to use only Required reinforcement Module not Provided... module. is there any idea?
thank you
Any reason why you want to use Polish rebars with the US code? Perhaps you should use the American version of these two instead? Mind that you should redefine both the member type and calculation parameters.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
No matter what i choose. it always shows Rebar results in imperial format.
I have attached a new picture and file.
could you please help me?
thank you.
The file with reassigned code parameters.
