Diagram for walls
6 REPLIES 6
pevelor
952 Views, 6 Replies
Diagram for walls
Hi
I want to use a diagram illustrating the vertical load applied to a wall.
So far, I have only been able to use maps and thick of membrane forces.
Moreover, I want to find an average value or integral value.
Can someone please help me with this?
Kind regards
Peder
6 REPLIES 6
Artur.Kosakowski
in reply to: pevelor
Peder,
Could you attach a sketch which illustrates what the diagram should look like please?
Artur Kosakowski
pevelor
in reply to: Artur.Kosakowski
Hi
I diagram looking like this would be nice
Is that possible?
Regards
Peder
Artur.Kosakowski
Here you are.
Artur Kosakowski
pevelor
Thanks Artur.
Would it be to much to ask if you could make a short video illustrating how you would do this in structure type 'Building design'?
One reason I want to check these values is to investigate the minimum thickness of a wall in regards to just compression.
Artur.Kosakowski
Here you are.
Artur Kosakowski
pevelor
supernice.
Thanks a lot
