Hello friends,
I'm tried to make some correction by using Detailed Structure Correction option. But nothing happens.
Can you explain in detail how to use this option?
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
Solved by Rafal.Gaweda. Go to Solution.
too small Precision - must be bigger than mentioned distance
Rafal, I've used from 0.00001 to 100 m and no results in any case.
Roman Zhelezniak
Maybe I'm dumb, but this option don't work in my hands. Also, i'm read help, but...
Roman Zhelezniak
Thank you, Rafal.
The algorithm is not worked like I'm thought.
Also, in Russian language help, this string "Structure corrections are performed only then when the distance is smaller than precision" is absent.
Roman Zhelezniak
