Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Designing a Masonry Wall
5 REPLIES 5
5199 Views, 5 Replies
Is there anyway to do a masonry design in Robot 2011?
James
5 REPLIES 5
Artur.Kosakowski
I'm sorry but there is no such design module in Robot.
Artur Kosakowski
Is it possible at least to modeling a brick wall (without design it), which will work without connection with slab and will not participate in bending stiffnes of slab? Just vertikal transfer of loads from above.
If you want to transfer the load then I think you have to connect it to the slab. Try to make it very thin or reduce its moment of inertia in the same dialog.
Artur Kosakowski
Hi Artur, how to transfer the load from floor to supported wall (in middle of floor)? and how to define connection between floor and walls? do we need to divide floor into many pieces ? some guy said : release liner in top & bottom of wall, is that solution ok?
Refaat
in reply to: Tuan.nitma
Hi
" how to define connection between floor and walls? "
As a pinned connection ( Linear release - Rx).
 "do we need to divide floor into many pieces ? some guy said : release liner in top & bottom of wall, is that solution ok? "
Yes , you are.
Aslo , you may take a look to these useful links too.
Refaat
http://forums.autodesk.com/t5/robot-structural-analysis/slab-supported-on-masonry-wall/m-p/5371097#M...
http://forums.autodesk.com/t5/robot-structural-analysis/how-do-i-model-brick-walls-in-robot/m-p/4352...
