The inclined beam reinforcement export to ASD is not supported. You can try the following solution:
Window > Add View > Beams > Beam Reinforcement Edition and save the generated drawing as dxf/dwg
Mind that this is going to be an ASD file but a vanilla AutoCAD dwg instead.
Artur Kosakowski
