Discussion Groups
Robot Structural Analysis
Valued Contributor
pevelor
Depressions in slabs
140 Views, 3 Replies
08-09-2012 01:16 AM
Hi
I have a slab with depressions, and I am wondering the correct way of modelling this.
What I have done is the following:
1. Define contour of the main slab.
2. Assign thickness to the main slab
3. Define a new contour inside the first slab for the depression.
4. Assign thickness for the depression
I am afraid the stiffness might be incorrect if the main slab does not have openings where I assign new panels (depressions). In other words, will the stiffness be correct?
Regards
Peder
Please use plain text.
Product Support
Artur.Kosakowski
Re: Depressions in slabs
08-09-2012 01:29 AM in reply to: pevelor
Yes, it will.
Artur Kosakowski
Valued Contributor
pevelor
08-09-2012 01:50 AM in reply to: Artur.Kosakowski
Thats what I figured. So in other words, when I create a new panel inside another panel it will create an opening in the main panel....
The reason I got concerned I because of the values obtained in rc design
Could you explain why I get higher values where I have depressions? (All slabs have identical material)
Product Support
Artur.Kosakowski
08-09-2012 02:40 AM in reply to: pevelor
It will create a panel with elements of different thickness. If you create a contour then it will create an opening instead.
I'm sorry but having only the picture  I'm not able to figure out what you actually modeled. Please check values of displacements and internal forces first to understand the behavior of the structure (make sure that the model behaves as you wanted it to do). The reinforcement is just the secondary result so usually this is not the area you should start your investigation with.
BTW: I may be wrong but assuming that you have continues transfer of bending along the slab the same value should cause larger reinforcement in the part with the smaller thickness.
Artur Kosakowski
