Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Delete moving loads
11 REPLIES 11
Message 1 of 12
1066 Views, 11 Replies
Delete moving loads
Hello, I defined several moving loads and now I want to delete those I don't need, but the delete icon is not active for them. I deleted the auxiliary objects the loads are applied to, but the delete icon is still not active...What could be the reason I cannot delete them?
11 REPLIES 11
Message 2 of 12
Artur.Kosakowski
Artur Kosakowski
Message 3 of 12
in reply to: Artur.Kosakowski
Hello, so sorry, but I asked the wrong question, I mean I can't delete the vehicles I defined, I don't want to use them anymore, but the delete "X" icon is not active..
Message 4 of 12
Artur.Kosakowski
You should be able to delete all but one vehicle. Try to define a new moving load with one of the vehicles assigned. Afterwards you should be able to delete all other vehicles. Finally delete the moving load case you defined.
Artur Kosakowski
Message 5 of 12
Thank You, I tried, but it doesn't work. I deleted all the load cases I had, then made a new load case with one of the vehicles, but I can't delete any of the vehicles. Also I made a new model and I was able to delete the vehicles there. Still, in the first model I made, none of the six vehicles I defined can be deleted...
Message 6 of 12
Artur.Kosakowski
Attach this model please.
Artur Kosakowski
Message 7 of 12
What file should I attach..it says that *.rtd is not supported to attach
Message 8 of 12
Artur.Kosakowski
Message 9 of 12
Message 10 of 12
Artur.Kosakowski
Try to open the file in the repair mode and then delete the 'other' vehicles.
Artur Kosakowski
Message 11 of 12
Thank You, this worked. Now there is only one user defined vehicle in the list, does the fact that it's in list mean that it's used somewhere in the model, or just according to Robot there have to be minimum one vehicle in the list? Anyway, Your answer helped! Thank You!
Message 12 of 12
Artur.Kosakowski
One has to be available.
Artur Kosakowski
