Hello
I have a structure with timber and steel beams and columns. The structure as shown on the attached file. The deformation as shown on the attached file is 45.7mm but on the same screen show that the max deformation is 101.1mm. Where is this difference comming from? Which one is correct?
Best regards
Waleed Khalid
Please check http://forums.autodesk.com/t5/Robot-Structural-Analysis/Sending-bigger-files/td-p/3795062
