Hello to all .. how i can know the exact vaule of deflection for these two models .. first one Deck slab with cross girder& main girder .. and Deck Slab without cross girder(JUST main girder) ..
I know there's difference in the values but i can't get it by robot ...
Solved by Artur.Kosakowski. Go to Solution.
Try to either display deformation (instead of detailed deflection) in the Bar diagrams dialog or display map of displacements rather than stresses.
There's no maps of bars .. just tha active one maps on solids ... and where's displacement maps ??
It's solid modeling not shell
You can use maps for solids with descriptions switched on.
