Could anyone tell me what would be the best solution to extract the RC plates from a 3D model (necessary for earthquake verification) to a 2D plate design (for reinforcement design). Is there any way that I export a single plate from a 3D model with all support conditions into 2D plate design?
Solved by Artur.Kosakowski. Go to Solution.
Solved by StefanoPasquini6790. Go to Solution.
Thank you Stefano, that helps. I want to check the whole structure for earthquake in 3D and design the plate in 2D as I find it more accurate. It would be nice if I could save support conditions as well from 3D but I guess I'll have to do it manually.
Best regards,
Balázs
Well, if mean to analyse separately the slab from the whole model you can use the tool "save as sustructure" in the geometry menu.
Select the floor and walls below and above it. Then support walls and columns on the 'outer' ends.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
