Hi
Please find the attached files. What is the difference between dashed and solid lines?
Top and bottom reinforcement.
Hi
In the attached files dashed and solid lines are of the same number and distribution. How could be top and bottom reinforcement (please watch carefully @ the attached files). Can the top reinforcement be in the same position as the bottom reinforcement?
Can you really see any numbers on the pictures you attached ?
Why not when reinforcement bars are the same?
