Hi guys,
Tony
Hi Tony,
some summary on using damping in modal, spectral and seismic cases.
Damping defined in advanced parameters of modal case
is used in:
1/ damping correction of elastic spectra in these seismic codes where it is possible - for instance in EN-1998-1-1 (Eurocode 😎
2/ in calculation of complete quadratic combinations (CQC) and double sum method (2SM) combinations - see appropriate Help topic
Damping defined in spectral analysis is not used directly in spectral analysis calculations- it can be treated as some identifier of various spectra here. It is used when preparing spectra in case of spectra interpolation:
Above settings correspond to different actions so there is no risk to consider damping "twice".
If this post answers your question please click "Accept as Solution". It will help everyone to find answer more quickly!
This damping setting would be used only when using this spectra in Spectra Interpolation:
Thanks for your reply Pawel,
Perhaps the dialogue box should be removed from it's current position, it's a bit misleading.
Thanks anyway,
Tony
Hi Tony,
sorry for incomplete/incorrect answer in my previous post:
damping from properties of spectra is used in spectra averaging not only in spectra definion but also when using averaged spectra directly in spectral load case - see the screen capture below:
In such case the actual relative damping used to calculate averaged spectra will be taken from advanced parameters of modal case preceding this spectral case.
