Hi to everyone!
I have such an issue. I was designing a simple slab in robot and using a dwg background for that. When I assigned a countour I switch off the background because then I didn't need it (made a pulp light off) but now I can't switch it on. Are there some restrictions on using backgrounds?
Thank you for your attention
I've already had the latest update (SP2). Do I need to do that? I just don't know where is that cfgusr folder located(
"c:\Users\user_login\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis Professional 2015\CfgUsr"
