Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
DRAW SLAB THAT IS TRUE
1 REPLY 1
huyxp
350 Views, 1 Reply
IN REVIT STRUCTRAL
I don't know method draw slab is true?
please see this picture below
- method 1: draw slab as - pick support at beam
and the analytical model this below
- METHOD 2: draw slab as method draw rectangular
and the analytical model differrene in method 1
PLEASE HELP ME FOR SELECT METHOD IS TRUE
TKS ALL PRO
1 REPLY 1
Artur.Kosakowski
in reply to: huyxp
Assuming that you want to export such model to Robot the 1st solution is similar to the way you (usually) model the same structure in Robot. For the 2nd approach you will have a narrow strap of surface elements between the slab edges and beams which you usually want to avoid.
Artur Kosakowski
