IN REVIT STRUCTRAL
I don't know method draw slab is true?
please see this picture below
- method 1: draw slab as - pick support at beam
and the analytical model this below
- METHOD 2: draw slab as method draw rectangular
and the analytical model differrene in method 1
- PLEASE HELP ME FOR SELECT METHOD IS TRUE
TKS ALL PRO
Solved by Artur.Kosakowski. Go to Solution.
Assuming that you want to export such model to Robot the 1st solution is similar to the way you (usually) model the same structure in Robot. For the 2nd approach you will have a narrow strap of surface elements between the slab edges and beams which you usually want to avoid.
