Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
DESIGN - RC BEAMS - Armed Beams
10 REPLIES 10
Message 1 of 11
ALEJANDROFELGUEROSAFUENTES1370
726 Views, 10 Replies
In the module for the manual assembly of beams has detected the following problem: After entering the armors and calculated the beam, the program does not consider the lower reinforcement in the beam resulting in that section and that does not meet resistance bending moments positvos to zero .. When going to see the diagrams of results in the corresponding flange concrete reinforced module shows that diagrmas not appear in the bottom of the graph corresponding to the resistance due to the lower positive reinforcement
10 REPLIES 10
Message 2 of 11
Could you send the rtd file with such beam? How the reinforcement was created - generated by Robot or using the typical reinforcement dialog? Other way?
Artur Kosakowski
Message 3 of 11
Thank you.
The reinforcement has been created using the typical reinforcement dialog.
Please find attached the .rtd file with the beam. The file has been zipped in order to send it to the discussion group.
Regards.
Message 4 of 11
Follow the steps shown on the attached picture.
Artur Kosakowski
Message 5 of 11
Tahnk you.
We tried your solution but the problem persists.
Attached is a picture with the armed beam diagram.
Regards.
Message 6 of 11
http://screencast.com/t/6B08ILGgR
Artur Kosakowski
Message 7 of 11
We are unable to do the same as on your video. We have tested three worksation with Robot.
We are using  Robot 2013 and Windos 7 64 bit on a Dell Optiplex 380.
Thank you.
Message 8 of 11
Send me the rtd file and a picture that shows the actual issue please.
Artur Kosakowski
Message 9 of 11
The .rtd and image you requested.
regards.
Message 10 of 11
As far as I can see the diagram is displayed correctly when you first freeze reinforcement and then launch calculations as shown on the attached picture.
Try to install SP3 for Robot 2013 from:
Robot2013SP3
Artur Kosakowski
Message 11 of 11
After installing the service pack 3 and hot fix 4 the problem has been solved.
Thank you.
Regards.
