In the model attached, I'm trying to cut the panels by a XY plane with Z=0. Model 01 is original and model 02 after cutting. I'm using "Cut by plane..." command.
As you can see the result is not the one expected. The resultant panels have been modified. Can anyone please explain what I'm doing wrong?
Thank you, regards,
sanjuan100
Solved by Rafal.Gaweda. Go to Solution.
Download, unzip this addin, run it and convert panels to standard ones, then Cut them
Thanks Rafal,
I'm in the process of doing this but will it work for panel created using revolve?
And does it keep the loads? It says it doesn't but just checking, it's the most important work in my case.
sanjuan100
As far as I can see - yes. But always check.
Of course not on your model - after converting panels all loads are lost.
