Discussion Groups
Robot Structural Analysis
Distinguished Contributor
Accepted Solution
Custom rebar database
450 Views, 6 Replies
07-27-2012 04:05 PM
I cannot edit a custom reinforcing bar database. The Open button does not work. See attached video: http://screencast.com/t/3mrlqUinWph
Please use plain text.
Product Support
Re: Custom rebar database
07-30-2012 12:48 AM in reply to: PatrickEC
Patrick
copy
"c:\Users\user_login\AppData\Roaming\Autodesk\Structural\Common Data\2012\bar_EC.xml"
to
"c:\ProgramData\Autodesk\Structural\Common Data\2012\Data\Reinf\bar_EC.xml
Rafal Gaweda
gustavo.c.vasconcellos
09-08-2012 07:46 AM in reply to: Rafal.Gaweda
Hi Rafal,
I have the same problem and coping the files didn't work.
What else should I do.
Gustavo
Product Support
09-10-2012 02:26 AM in reply to: gustavo.c.vasconcellos
Have you copied it to correct folder?
Make a movie like Partick did to show how it works on your comp.
Rafal Gaweda
09-10-2012 02:26 PM in reply to: Rafal.Gaweda
Dear Rafal,
see the link to the video:
http://www.screencast.com/t/g8WkSvHLvP07
Gustavo
Product Support
09-11-2012 06:13 AM in reply to: gustavo.c.vasconcellos
Gustavo,
Your problem is different, editor does not work at all.
Check whether you have this file on your comp or not?
c:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\DBAccess\RBCTMdbEditX.dll
If you have it on disk plaese open windows Command Prompt in Admin mode, and regiter this dll by the command shown below:
Rafal Gaweda
09-11-2012 12:49 PM in reply to: Rafal.Gaweda
Thank you!! It is working now!
