I cannot edit a custom reinforcing bar database. The Open button does not work. See attached video: http://screencast.com/t/3mrlqUinWph
Solved by Rafal.Gaweda. Go to Solution.
Patrick
copy
"c:\Users\user_login\AppData\Roaming\Autodesk\Structural\Common Data\2012\bar_EC.xml"
to
"c:\ProgramData\Autodesk\Structural\Common Data\2012\Data\Reinf\bar_EC.xml"
Hi Rafal,
I have the same problem and coping the files didn't work.
What else should I do.
Gustavo
Have you copied it to correct folder?
Make a movie like Partick did to show how it works on your comp.
Gustavo,
Your problem is different, editor does not work at all.
Check whether you have this file on your comp or not?
