I know there is many topics about this subject but once more.. 🙂
So Can you help me for calculate critical buckling lenght for upper chord. If I got this kinda buckling shape and I got this kinda numbers.. I cant clearly understand or I am not sure what this critical coef. and precisions means maybe because my english skills isnt very best..
see attachment pics..
Thanks allready 🙂
Solved by Artur.Kosakowski. Go to Solution.
The buckling analysis in Robot is not intended for finding buckling lengths of elements of the model. This is the check of the stability of the structure as a whole. The critical coefficient is the information about the value of the load that would cause the structure (or its part) to loose its stability. The value of this load is equal to the load defined in the selected load case * critical coefficient.
Check also messages 2 and 7 here:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Buckling-Analysis/m-p/3280269
Ok.. I just read one kinda research where researchers is calculating backyards critical buckling lengt with robot?
Pdf below in finnish but see pictures 🙂
And other one in English
If you insist you can do the following:
1. Determine the mode (shape) that corresponds to the buckling of the element you want to calculate buckling length for
2. Check the axial force in this element for the selected load case
3. Multiply this force by the critical coefficient for the determined mode from the point 1
4. Calculate buckling length based on the determined value of the element's critical force (point 3)
Mind that the success depends on the correct execution on point 1 and the decision which mode and element to investigate is now in your hand
Ok I Think I got it most of parts..ofcourse step by step instructions with pictures would be nicer but first I can try it myself 😉
ps. Thank you !
Handle with care
Please note that I'm not in the position to determine which mode to choose for which element of a model.
Hehe I Know, this is only for studying the subject not for real structure calculating.. there I stand in Eurocodes buckling lengts for the chord in compression
Thank you very much!! 🙂
